Oil Pressure
Old Jul 17, 2006 | 06:23 PM
  #41
TS6's Avatar
TS6
I'd be suspect he didn't install the rear plug as well.
If he didn't R&R the motor then you might have to yank it and bring it to him. I guess I'd prove to him he didn't install the plugs, install them, and go from there. If it has damaged bearings it won't take long for it to surface.
Old Jul 17, 2006 | 06:28 PM
  #42
ricethis98's Avatar
right, how do i prove it to him, and what do i say to him? how soon will i know if my bearings are fucked??
Old Jul 17, 2006 | 06:57 PM
  #43
Ferocity02's Avatar
How long have you ran the motor without any oil pressure. I'd snap a picture and send it to him to show him that it doesn't have a plug.
Old Jul 17, 2006 | 07:08 PM
  #44
jay_99z's Avatar
Take a picture and send an email to him. To be safe I wouldn't say anything about possible damage in the first email. You don't want him on the defensive...you want him to admit to it. If the bearings are crap...yeah it's his fault. After all......the guy already told you he put them in.
If the bearings are messed up you should know very soon.If you don't hear the knocking....you'll see metal in the oil.
Old Jul 17, 2006 | 11:08 PM
  #45
ricethis98's Avatar
I ran it a couple different spurts, probably a total of 30 seconds. Oil made it to the filter so there had to be a tiny bit of psi
Here is exactly what he told me. I called him and told him that i have zero oil pressure and i asked him about these two plugs. He told me " if we removed the plugs, then we always put them back in." I told him that I didnt want to take it all back apart to check, he then said " i cant 100% guarantee that they are in". He told me that he thought it was an electrical issue and to check the wiring. this was 7/10.
I want to make sure i do everything right so that if i have any issue with my build bc of this, that it is his fault. I dont know if he has an email adress to send a picture. I took a picture with my cell phone and u can see that it is missing. It is a business, a machine shop, not just a one man operation.
I ordered the front plug and a new O ring bc im already in there. I am going to plug the hole, replace the o ring, and check for pressure. If I have pressure, cool, ill check for bearing damage like a hawk. If i still do not have pressure, Do I go to him and tell him the rear plug is not there and he needs to take care of this?????? Im so sick of taking things apart after there already assemble
What other advice do you guys have?? Sorry if this is annoying but I want this to be over with and want to know how to approach the builder.
Thanks
Old Jul 18, 2006 | 07:10 AM
  #46
ricethis98's Avatar
t t t
Old Jul 18, 2006 | 12:45 PM
  #47
DrkPhx's Avatar
Is this a local engine builder?
Old Jul 18, 2006 | 05:35 PM
  #48
ricethis98's Avatar
yea, here in Rochester NY. anyone who is into engine work around here knows who they are.........
Old Jul 18, 2006 | 11:30 PM
  #49
ricethis98's Avatar
b u m p
Old Jul 19, 2006 | 07:12 AM
  #50
ricethis98's Avatar
t t t
Old Jul 19, 2006 | 02:34 PM
  #51
tech2's Avatar
who are they? i thought everyone went to texas for that kind of stuff
Old Jul 19, 2006 | 05:49 PM
  #52
ricethis98's Avatar
haha its just a machine shop here locally. here is something i noticed among all the research i did. on the rear of the block there is a copper hex head plug located near the oil filter. behind that gives u access to look up and see if the rear oil galley plug (barbell) is installed. you cant install it from here but atleast u can look and see if its in. ill be checking that real soon............... good thing i waited and didnt go through the hell of removing the tranny to check it.
Old Jul 19, 2006 | 10:50 PM
  #53
ricethis98's Avatar
t t t
Old Jul 20, 2006 | 06:15 PM
  #54
ricethis98's Avatar
t t t
Old Jul 20, 2006 | 11:12 PM
  #55
ricethis98's Avatar
ok so i drained the oil bc i wanted to check for metal glitter in the oil from the bearings. there was a small amount of gunk on the magnetic plug, a tiny shard of metal, but nothing to raise concern or to show bearing issues. the problem im having is the color of the oil. the engine ran for a max of 30 seconds or so, the oil is very dark. it has a slight green hue to it as well. never seen this before.
what should oil look like on a brand new motor? i used a ton of black assembly lube on the cam, and im not sure what the builder used for lube, it might have been green or red.......
one thing to keep in mind before answering to this would be that bc the galley plug was missing, i dont think enough oil would have gotten to the bearings for there to be metal in the oil...........
Old Jul 21, 2006 | 03:16 PM
  #56
ricethis98's Avatar
feedback people
Old Jul 21, 2006 | 04:31 PM
  #57
gun5l1ng3r's Avatar
I would tell the shop owner to fix it the correct way, including tearing it back down and checking the bearings and replacing if need be.
Old Jul 21, 2006 | 05:23 PM
  #58
ricethis98's Avatar
anyone know anything about the oil???
Old Jul 21, 2006 | 10:30 PM
  #59
ricethis98's Avatar
t t t
Old Aug 19, 2006 | 02:44 PM
  #60
ricethis98's Avatar
ok here is an update.............. I put the front plug in and i replaced the o ring on the oil pump just for the hell of it, and i checked the rear plug and it is in.......... and no i didnt have to take the tranny off to check it . i fired it up and the pressure went thru the roof. thank god now i just gotta wait and see if the bearings took a hit..............................
what are the symptoms of bad bearings?
