Groove in the head from bent pushrod
Old Jul 9, 2006 | 08:27 PM
Sh4Dy's Avatar
Default Groove in the head from bent pushrod
missed teh 3-4 shift and hit 2nd. I pulled all the pushrods, a couple are bent. One rod left a groove in the head similar to this pic. groove in the head
Will I be ok just replacing the pushrods or would it be best to pull the heads?
Old Jul 9, 2006 | 08:41 PM
ArcticZ28's Avatar
As long as it hasn't cut a groove in such a way that it rubs against the PR, then you should be fine. As for what else may have happened to cause the bent PR (valve could be bent), I can't say.
