Help with advancing cam
What am I doing wrong? Of course the timing set comes with virtually no instructions.
I know older SBC adj sets have different sets of timing marks that accompanied the different keyway so you could use a dot-to-dot method. Only way I see to do it is change the keyway and use a degree wheel to set it in. EAch keyway should allow for a specific amount of advance/retard but its a guess since I didn't see any distinct markings
There are no marks on the lower gear like most adjustable timings gears have. No triangle, square or anything to indicated advance marks so you have to count back three teeth and assume same spacing based on grove(advance)desired.
They did say this in the instructions but it could have been worded a little simpler for the novice like me.
