what size pushrods?
Old Jul 10, 2006 | 08:12 AM
salspmp's Avatar
Default what size pushrods?
I will be getting a 231/237 comp cam, i have 5.3l pp heads, i have stock rockers and block..... what size push rods do i go with?
Old Jul 10, 2006 | 10:54 AM
PREDATOR-Z's Avatar
It depends if your heads are milled or not and what gasket thickness you are using.
In stock head height and stock gasket application you can use 7.425 for added preload and reduced valvetrain noise.
Old Jul 10, 2006 | 10:58 AM
Mr. Luos's Avatar
What is the stock preload on the stock lifters with a completely stock set-up??
Yeah...stock.
Old Jul 10, 2006 | 11:01 AM
PREDATOR-Z's Avatar
Yeah...stock.
In an LS1 .100 or a little higher. It depends which year and what is the head gasket thickness.
Old Jul 10, 2006 | 11:23 AM
Mr. Luos's Avatar
I believe the stock gasket is the .054" MLS.
Since we are here, what is the base circle of the stock cam?
Old Jul 24, 2006 | 12:59 AM
molson's Avatar
1999.
I would also like to know....
Have a Tr224 and am running Tr 7.4" pushrods.
I wonder if I need longer ones.car is pretty noisy.
