Can you check Rockers?
Old Jul 12, 2006 | 02:36 AM
killaz's Avatar
Default Can you check Rockers?
I have my valve covers off. I have been running the MS3 cam now for about 4 weeks. I was wondering if there is any way to check and make sure the rockers are in good shape. I did not SEE and needle bearings. If i pull one is there anything i can look for? There is nothing unusiall going on i just have the covers off and was wondering if i could do any kind of visual check on them?
thx
Old Jul 12, 2006 | 11:51 AM
Nasty N8's Avatar
If they are already bad or about to be they will have alot of slop in the bearings. Or you will see the side bearing cages split. If they are not bad yet it is a great time to upgrade either to full rollers or have the stock rocker mod done. Deffinatly worth not taking a chace destroying your motor. Give me a call I can set you up.
Nate
