Mike Norris?
Mike tuned my 402, and the shop did the finishing touches (filled oil, coolant, checked lifter preload and swapped pushrods, re-routed some wiring) after I had my car towed there following the engine swap I did in my garage. The timing was horrible for me, the engine was months late from FFHP, and I was about to move to Colorado. I ended up having a shipping company pick the car up from Norris directly because I dropped it off at Norris' shop late, and then more **** kept going wrong (clogged cats), and I was already in CO by the time Mike got back in town to finish the tune. None of that's Mike's fault, of course.
After the car made such low numbers on the initial tuning, I also had them install an X-Pipe with high flow cats, and bought a air-intake and mufflers from them that they installed, too. The bill was pretty hefty, which is to be expected considering all the crap I had them do.
IMO, if you are gonna spend a bunch of money, do it at one place. I bought the 402 from FFHP (who are now out of business), and they recommended patriot heads, and said I should get a big cam (the 238/244 I ended up with was on the small side of their recommendation).
Then I was rushed for time when I installed the engine myself, and Norris' shop had to finish the job, which wasn't cheap.
Then when Mike was doing the tuning, he said the cam was way too big, and I should have gotten AFR heads. Between higher compression and a smaller cam, I would have had more dynamic compression.
Anyway, I ended up spending a bunch of money at several places, and still came out with only 450rwhp, in a 402. If I had it to do over again, I would have just dropped the car off at one shop, and let them pick all the parts, and do all the work, and just handed over a wad of cash. It would have been a lot less headaches, and probably cheaper, too.
- Miles
PS: Hope it doesn't sound like I'm bashing Norris, cause I'm not. I'm just saying I was dumb for spending a shitload at 3 shops, and then spending a shitload more because I was rushed at the end. Now FFHP is out of business, Mike says my heads suck and cam is too big and I need a FAST90, Patriot says the heads are fine and I need a *bigger* cam and a FAST90 and the tune may be bad, etc, etc, etc.
