Require 650RWHP engine for 1999 Vette
Mass Air flow...... gonna have to ditch that and go speed density
Fuel injectors, big, 55 lb or so
Heads – AFR ?? LS7X Warhawk ??...probably some ET heads, at least a 240/250 cc runner
Lifters.....solid roller
Rocker arms...shaft rockers
Valves...big
Valve springs....to be determined
Pistons...Forged
Rings...good ones
Connecting rods...billet, you gonna be running hard to reach 220
Push rods...damn good ones
Headers...big, 1 7/8 stepped to 2 inch
Exhaust... Also big, I dont know how much ex you can get under a vette
Tail pipes..see above
Engine block – LS7X Warhawk ???....or a c5r..you gonna need 450+ inches
Crankshaft.....Billet
Camshaft....BIG
Also, some more things you havent considered
If you plan on running that speed Cooling is gonna be an issue, oil and coolant.
Transmissions and rear ends also tend to overheat at those speeds
650rwhp normally aspirated on pumpgas, drive it cross country a VERY tall order, you cannot skimp ANYWHERE, over build where you can.
David
Cheers, Kev
Sydney Australia.
I know CT Corvettes (Steve) is looking for some project cars to get this done on and he's teamed up with Slowhawk for tuning so you know you'll have a solid and reliable ride. On this forum I think his name is Connecticut.
If you are really attempting this - good luck. If you have any $$ left over, please PM me
welcome to the site!
