H/C Install. Almost Done.
Old Jul 16, 2006 | 09:52 PM
viewsonic's Avatar
Originally Posted by tsench
hey howmuch u spent on it...care to share where u get all thepart thx
This setup would cost you around 5k
I already said where I got most of the stuff in post 12... yah I know it is a long post lol. But read it
Old Jul 16, 2006 | 11:00 PM
ArcticZ28's Avatar
Congrats man! I'm sure you're feelin a like a pig in **** after putting everything together and making those kinda numbers. My car is being tuned at the moment and I'm hoping to hit close to the same sorta numbers, but with LS6 intake and without ET heads .
Old Jul 16, 2006 | 11:08 PM
viewsonic's Avatar
Awesome! Let me know what you end up making! Just imagine the power you would be making wit ET heads on that 408
Yup it feels good to be in the 500rwhp club....
Old Jul 16, 2006 | 11:44 PM
CNB's Avatar
CNB
Very nice!
Old Jul 17, 2006 | 09:59 AM
Shu's Avatar
Shu
awesome numbers! What kind of weight reduction have you done?
Old Jul 17, 2006 | 10:12 AM
viewsonic's Avatar
Just to name a few things off the top of my head:
!back seats
!exhaust
!various heavy brackets
!heavy heat sheilds (no longer needed since exhaust does not go out the back)
!spare tire/jack/tools
Lighter wheels
There is abunch of other stuff... but I don't remember right now.
Old Jul 17, 2006 | 06:19 PM
viewsonic's Avatar
bump.
Old Jul 17, 2006 | 09:52 PM
JakeFusion's Avatar
Super Hulk Smash
Nice setup. That torque is unreal with that camshaft profile (at least with the Comp grinds), but that's what a high DCR will do.
Old Jul 17, 2006 | 09:55 PM
2001 Pewter WS6's Avatar
Restricted User
Mine will be going together this weekend... We shall see what kind of power it can make...
Old Jul 17, 2006 | 10:07 PM
viewsonic's Avatar
Here is a better graph:
Old Jul 18, 2006 | 11:01 AM
TheBlurLS1's Avatar
That's what she said...
Those numbers are outstanding!
As for the PCV problem, you could just delete the whole thing all together and run a breather. I ran a catchcan setup for a while but ended up getting so much blowby that it started coming through the fresh air tube (plugs into tb). Not sure if it's the same setup on a GTO or not.
Metco makes a nice one that screws into the oil fill cap neck (thunder racing), or you can drill a hole in the stock cap (or a cheapo parts-house one) and pop in a 1-1/4 breather also from the parts house.
This guy did it for way less than the Metco costs (which I have )
https://ls1tech.com/forums/generation-iii-external-engine/536787-deleted-pcv-pics.html
Make sure you put some fresh oil in her every 3k or so and you'll be golden.
Old Jul 18, 2006 | 11:06 AM
  #32
viewsonic's Avatar
https://ls1tech.com/forums/showthread.php?t=536787
Thanks man that is some good info!
It seems my PCV system has settled down a bit since the tune.... It seems to be filling at a normal rate again... (I don't know it was filling so fast before?)
Old Jul 18, 2006 | 12:53 PM
  #33
Joel_SS's Avatar
Just an update.
Started taking parts off my car this morning to take the driver head off...
Took the intake off and noticed the rear coolant plug was loose... OH ****!
I am very happy to find out that my heads are actually not leaking! and it is actually just a very minor problem!
(It was not that stupid of a mistake.... the bolt was about 1/8" long with my new heads and did not seat down on the plug all the way... When I bolted it up I thought it was tight but it was not tight on the plug... My fix: cut the bolt. )
All better
Now I just need to find a better solution for the PCV. There is too much blowby for my liking...
I am soooo happy to know my heads are indeed properly sealed and I dont have to take them off
I got owned by the rear coolant plugs as well.. OCngrast on the new setup!!
