bad rings??
Old Jul 18, 2006 | 01:10 PM
Z'mnypit's Avatar
Originally Posted by TheCarKid
Tested my car last night with the leak down tester. Everything was fine until I got to cylinder 5. Set the tester @ 100 psi and had 85% leakdown. I had the valve covers off and you could hear the air coming out of the engine and you could smell the oil vapor as well. I'm gonna tear it down to see what happened but it looks like bad rings.
Sounds like you found your problem. You gona go for a rebuild or a new motor?
Old Jul 18, 2006 | 01:28 PM
TheCarKid's Avatar
Don't know yet. Looking into it. At work will write more later
Old Jul 19, 2006 | 01:13 PM
TheCarKid's Avatar
So I'm tearing down the engine tonight and looking to see what else i need to replace. Also looking at a 383 block from a friend of mine and if it's in good shape it's goin in the car. Now I just have to figure out if I'll be able to get the block out of the car with the heads off or if I have to drop it out the bottom. If I don't have to drop it I don't want to.
Old Jul 19, 2006 | 01:23 PM
Z'mnypit's Avatar
Last 3 times Ive pulled the motor with the heads still attached along with the trans from the top with no sweat. Just takes some a little steering thats all. Now trying to get them to go back in is a different story. Ill leave the trans off to get it back in. GL!
