PCV system. PLEASE HELP!
Old Jul 16, 2006 | 09:53 AM
viewsonic's Avatar
Default PCV system. PLEASE HELP!
Hey guys I just put on new heads yesterday and pulled off the intake today b/c I thought I had a leaky head gasket... turns out it was just the plug in the back of the head not screwed down tight.
Anyway I noticed that there is a large amount of oil on the intake ports of the heads. I am not pleased with this...
I already have a catchcan. and it is fills up fast now...
I was wondring what else can I do?
Instead of running the other hose coming from the catchcan and into the intake... can I put a breather on the hose and cap the intake?
So it would be a hose coming from valley cover to catcan then to breather with a capped intake.
I am worried about Vacuum problems... I really do not know much about Vacuums.... But I would really like to keep the oil out of my heads....
Please help me with this!
Old Jul 16, 2006 | 10:08 AM
PREDATOR-Z's Avatar
I had similar issues with my old block, so when I rebuilt i went the LS6 PCV route, no more issues as of yet.
Old Jul 16, 2006 | 10:20 AM
viewsonic's Avatar
Hey Pred,
Besides doing a LS6 PCV... Is there any thing else I can do?
Is the "valley cover to catcan then to breather with a capped intake" possible?
Thanks man, I really value your opinion!
Old Jul 16, 2006 | 10:40 AM
PREDATOR-Z's Avatar
No need for catch can if you go breather route.
Either driver to passenger link and 1 breather at oil fill tube, or 1 breather in back of driver and 1 at oil fill tube
(both with capped intake)
Old Jul 16, 2006 | 10:46 AM
viewsonic's Avatar
Thanks Predator.
But I am a little confused... Just to let you know I have a LS2.
Right now there is the:
Hose that comes of the valley cover and goes through a catchcan which is then dumped in the IM.
Then there is a hose that comes off the passenger valve cover and then dumps in the Intake tube right before the tb.
I would really really appreciate if you could explain to me how I would set this up! Thanks!
Old Jul 16, 2006 | 11:08 AM
PREDATOR-Z's Avatar
sorry i didn't pay attention to the LS2 part.
That means you have a LS6 PCV setup (same same).
Is your car a LS2 transplant or a goat?
1- raise the catchcan position to make the angle steeper for the oil to climb.
2- If the oil is comming from the can, then you need to baffle the passage to reduce oil suction.
3- oil could be comming via the cover to TB opening, you could run a clear fuel filter in line on that hose to verify that.
Another choice is run a breather on the oil fill tube and cap valley cover, valve cover, TB and intake.
It is not normal to be sucking so much oil.
Old Jul 16, 2006 | 12:51 PM
viewsonic's Avatar
It is not just oil... It also has a lot of water/condensation in it... I bet it is from leaving my motor "open" for 3 weeks.
I think I may go the breather route. Do you think it will be ok to do this?
I don't want to screw anything up...
Thanks soo much man!
EDIT: it is a 2005 Goat
Old Jul 16, 2006 | 01:52 PM
viewsonic's Avatar
How about this:
Run a hose from the Valley cover to some sort of a vacuum pump and leave it open to air?
Will this work?
Where would I be able to buy a small vacuum pump like this?
