The Tv2 on a 113 is a nice cam and quite a rever, and I mean high reving. You can make power till 7000 if you can feed it enough air. However it tends to be sluggish on low side because of its VE's and and low DCR on stock compression. You are gonna need some tight gears to make up for it at least. The 112 +2 would have been better. |
TSP wont custom grind the 231/237? and did you buy the T2 ? and dont forget the 500 youll need to spend on the dyno tune |
© 2024 MH Sub I, LLC dba Internet Brands
