LS1 heads worth porting?
Old Jul 19, 2006 | 01:26 PM
TheCarKid's Avatar
Default LS1 heads worth porting?
Are LS1 heads worth porting to put them on a 383 with a TReX?? If not, what heads will work the best with that combo?
Old Jul 19, 2006 | 02:37 PM
black01_WS6's Avatar
the ls1 heads even with a decent port job are not goign to be in your best interest. You can get a set of ls6 heads pretty cheap from one of our sponsors. You could pick up a set from patriot perfromance and then get the worked over and you will be happy.
Old Jul 22, 2006 | 07:53 PM
Pimpium57's Avatar
https://ls1tech.com/forums/showthrea...light=tea+5.7L
Old Jul 22, 2006 | 08:00 PM
ArcticZ28's Avatar
Patriot has 243 heads new, ported, and assembled for under $1k. There have been a couple threads about it in here.
Old Jul 22, 2006 | 09:18 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
roger that.
Old Jul 22, 2006 | 09:51 PM
JZ'sTA's Avatar
I personially wouldn't use the PP heads or a ported LS1 head.
I just can't see the reason to spend a extra 3000+ dollars doing a 383 bottom and and being cheep on the top end.
Sure the Patroit heads will work and work well but so does the stock 346.
Why go with a bad *** bottom end and a decent/good top end?
Old Jul 22, 2006 | 09:55 PM
RrCoX22's Avatar
because the bottom end ran all the money away to leave none left for the top end
Old Jul 22, 2006 | 10:09 PM
TAQuickness's Avatar
If I were you, I'd just reuse the stock heads until I had the bones for a better top end. Since you gotta do it twice, might as well save as much as you can on the first round.
Old Jul 22, 2006 | 11:20 PM
Pimpium57's Avatar
Very good point.
Old Jul 24, 2006 | 10:12 PM
JZ'sTA's Avatar
Budget was never brought up in his question.
If he spent all his money on the bottom and and uses a cheep top end then he will have many stock bottom end H/C cars running right past him.
