cam only low 11's
Old Jul 20, 2006 | 05:40 PM
bad6as's Avatar
Default cam only low 11's
whitch cam could get down the track with a et around a 11.2
Old Jul 20, 2006 | 06:00 PM
black01_WS6's Avatar
well my cam is running in the high 11's and with some juice it would be low 11's.
Old Jul 20, 2006 | 06:45 PM
sickss228's Avatar
I was running 11.87 with a 2.0 60' 3680 raceweight with a CARTEK 2x (224/228) cam only. Some slicks and skinnies and weight reduction will get you close if you are a good driver.
Old Jul 20, 2006 | 09:01 PM
MNR-0's Avatar
Hi-stall, 4400+ and 240+ cam. Trex should work nicely. If M6, 6000rpm clutch dumps. Thing is, you need to set your car up to handle what it will need to make 11.2s a reality. That will cost way more than just a cam. Its not hard to make the power to achieve low 11s. It is hard to balance the car so it is capable of doing all it needs to achieve that.
Old Jul 21, 2006 | 01:43 AM
hawk232's Avatar
quoted for truth...
Old Jul 21, 2006 | 01:46 AM
Hennytime's Avatar
Hi-stall, 4400+ and 240+ cam. Trex should work nicely. If M6, 6000rpm clutch dumps. Thing is, you need to set your car up to handle what it will need to make 11.2s a reality. That will cost way more than just a cam. Its not hard to make the power to achieve low 11s. It is hard to balance the car so it is capable of doing all it needs to achieve that and not breaking
fixed
Old Jul 21, 2006 | 01:51 AM
99BackNBlackZ28's Avatar
I've gone mid 11's w/a hell of alot less than a 4K+ converter & 240+ cam.
Old Jul 21, 2006 | 01:57 AM
RoastEmSS's Avatar
ur gonna need 12 bolt + slicks most likely for an m6 to put down those numbers cam only
Old Jul 21, 2006 | 06:10 AM
2camaros6702's Avatar
I have run a 11.5 @ 118.0-mph with a 1.55-60' in a car with just lid cat-back and a 125 dry shot with dyno tune, and slicks spraying out of the hole. But it was an A4 car. So you dont need a lot to run 11s.
Old Jul 21, 2006 | 07:07 PM
bad6as's Avatar
i wanted to spray a 100 shot to get their but after hearing the bottel only last about 5 passes i was starting to think about a cam.
err i dunno, what about a 11.5?
Old Jul 21, 2006 | 07:45 PM
Michael4034's Avatar
I was running consistent 11.3's with mods in sig with a LS6 motor. they should drop alot with my LS2402 currently being built. Oh & my car is about 3650lb!
Old Jul 21, 2006 | 07:46 PM
bad6as's Avatar
size of your cam?
Old Jul 21, 2006 | 09:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
The 98 heads will limit the HP gain on a Cam.
What do you run now?
Old Jul 21, 2006 | 11:18 PM
Studytime's Avatar
Jason99ta went 11-teens with the TR230/224 cam. It's certainly a player in the field.
Ben T.
Old Jul 21, 2006 | 11:49 PM
99RedTransAm's Avatar
my friend's 98 m6 Z28 went 11.3 with bolt on's and 100 hp wet shot.
