priming oil system
My 408 I had assembly lube on all the bearings, and when we were cranking it over it made oil pressure on my mechanical gauge then we fired it up.
ABSOLUTELY DO NOT DO THAT. YOU WILL SCREW SOMETHING UP.
either use the starter or turn it over by hand. you don't really have any other options.
if you're feeling ambitious, you could remove the front cover of the oil pump and pack the pump full of petroleum jelly. that will keep the parts from corroding and will serve as a primer when you decide to start the engine.
That's the one. GM actually has a special tool to prelube the engine using that port. Kent Moore tools are way pricey, though.
