PRC Terminators or PRC LS6?
Remember the valve setup we use on the ls6 heads gives us extra p/v!!.035" is about 59cc to 60cc range!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Are you talking about the 112+0 or the 113+0
The 113+0 will have aproximately 8.34 DCR on 59 cc with stock gaskets.
The 112+0 will have ~ 8.47 DCR on same setup
can we confirm this jason? also what does that equate to for static compression?
why thank u
