Is there a solid roller set up for 346??
Old Jul 27, 2006 | 05:52 PM
03 BUSA's Avatar
Default Is there a solid roller set up for 346??
Does any one know if there is a solid roller setup for a stock displacement LS1?
Old Jul 27, 2006 | 06:11 PM
kickassT/A's Avatar
yes... all the parts are the same
Old Jul 27, 2006 | 06:34 PM
03 BUSA's Avatar
Old Jul 27, 2006 | 06:36 PM
jrp's Avatar
jrp
SN95 Director
just need a solid lifters, solid roller cam, and solid roller valve springs.
Old Jul 27, 2006 | 08:12 PM
CamKing's Avatar
We run solid rollers in the Daytona prototype engines, and they're smaller then stock displacement.
We have a drop-in solid Roller lifter, and we use a PSI spring that fits the stock heads and valve retainer.
Here's the different profiles we have available
SR Series Street Rollers
If you're comparing specs to a Hydraulic Roller, add 4 degrees.
Hydraulic Roller 224 = 228 SR series Solid Roller
