How to check springs
Old Jul 31, 2006 | 09:33 PM
FstBlkz28's Avatar
Default How to check springs
What tool do I need to test my valve springs to make sure they are still good? Where can I get it?
TIA
Old Jul 31, 2006 | 09:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlmиąŧя
How many miles are on the springs and what springs are they? I assume that you have run them on the 230 cam...
Old Jul 31, 2006 | 10:08 PM
Marc '99T/A's Avatar
His cardomain site says Comp 918's.
Old Jul 31, 2006 | 11:16 PM
ЯєŧąяĐ Єlmиąŧя
I ran 918's on stock cam, 222/226, 230/232, and 244/248. Still going! about 17k I would assume.
Old Jul 31, 2006 | 11:32 PM
2xLS1's Avatar
Google - Valve Spring Tester
You can buy new springs cheaper than most good v/s testers cost.
Old Aug 1, 2006 | 12:07 AM
FstBlkz28's Avatar
Ok thats what I was really wanting to know, wether its even worth it to check them or just replace them for good measure and security.
They've been on the car, w/ the TR230 lift - .575/.563 for about 17,250miles ~1 year.
Old Aug 1, 2006 | 12:20 AM
2xLS1's Avatar
Find a local machine shop that has one and have them test a few. Don't be surprised if they are just fine.
Old Aug 1, 2006 | 12:21 AM
staringback05's Avatar
depending on the cam, springs and use....anywhere from 20k to 40k....most of the guys i know just do it once a year
ЯєŧąяĐ Єlmиąŧя
Yeah, your due.
Old Aug 1, 2006 | 12:22 AM
ЯєŧąяĐ Єlmиąŧя
20-40k? Not on an aftermarket cam. 20 is pushing it in most cases.
Old Aug 1, 2006 | 12:32 AM
well then some sponsors should change there site info. ive known of a ls1 with a cheatr that had the same springs for 35k....but like i said most guys i know change them around a year...which would be like 10k-20k
