B1 vs Hot Cam
I was originally thinking Hot Cam because I would probably only have to change the springs once and forget about it since the lift is not that high. But maybe B1 would be better..
(I have to remain emissions legal also)
What kind of springs should be used with a B1 cam on stock heads? Also, will this cam require changing springs very often? The lift doesn't seem that high...
Thanks!
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
i use 918 springs with my b1 (stock heads).
i think both cams are great. B1 probably makes peak hp higher in the RPM range (mine peaks around 6300). hotcam probably lobes harder because of the 112 lsa (versus the 114 lsa of the B1). but i didn't want something that shakes the car so thats why i got the B1. and its very proven on the dyno, street and track.
good luck!
Can someone post up the hotcam specs?
B1-221/221 .558.558 on 114
Only thing I know on the Hotcam is that the Lift is .525?
As for springs, Comp 918s or something comparable should be fine. You dont need to go with a double spring setup, but it wouldnt hurt.
LS1 Hotcam 218/227 .525.525 LSA 112
B1 221/221 .558.558 LSA 114
What I'm kind of getting from reading many posts is Hot Cam does not give great dyno numbers compared to other cams, but it does great on 1/4 mile times... Is this accurate?
B1 is harder is on the drivetrain. It will make more power at a higher RPM range.
Hot Cam is more reliable long term (with LS6 springs) It will make more power at a lower RPM range.
Tough decision. The price difference doesn't bother me. Plus the whole 918 spring issue kind of worries me.
Thanks for all the info!
The Hotcam will idle rougher, but peak sooner. The B1 will idle more smoothe and peak a little higher with a little better peak numbers. On the street with factory rev-limits I doubt there would be a whole lot of perf. diff.
-Nick
<strong> It's days like today that make me very happy I have LS6 springs <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> (running LS6 '01 cam), the temperature was 2 degrees this morning and even with 3500 stall I don't worry at all that I'm going to pop a spring and ruin the motor on the way to work. You give up some at the track, but the peace of mind can't be beat. The LS6 springs have proven to be the only dependable ones that don't require head machining. This limit's your cam choices though, of course, everything is a trade-off. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Exactly Dave, visit my thread going on right now and tell me what you think.
