Would an f-13 fit??
Old Aug 2, 2006 | 04:30 PM
redtail2426's Avatar
Default Would an f-13 fit??
right now i have a 228/230 cam xe lobes,i have .085 intake clearance and .135 on the exhaust..Would the f-13 fit??i think its 230/232 with lobes almost as aggressive as xe-r lobes..What do ya think...I checked my clearance with a dial indicator and checker springs..
Old Aug 2, 2006 | 04:55 PM
Xtnct00WS6's Avatar
Is the .085 the actual measurement you took or the number from adding a little bit because of the light checker springs? Tony from AFR has said that you can add .015 to the measurements when doing the light checker spring method. What's the advance and LSA on both cams?
Old Aug 2, 2006 | 06:06 PM
that was the actual measurment,,i remember tony saying that so then i would really have .100 or so..both cams 112 lsa and the f-13 would have icl of 110...the cam i have now has icl of 110.5.so pretty much the same..
Old Aug 2, 2006 | 09:42 PM
Xtnct00WS6's Avatar
I'm pretty sure you also need to consider the advance that's ground into the cam. It'll be tight obviously, but I think you might be able to get away with it. Keep us posted on the measurments!
