Need Help on changing motor
it an lq4 do i need to do any mod to make it fit in my 00 T/A i know i have to change the intake and oil pan also water pump but not sure the crank shaft will bolt right in my A4 transmission
i try to bold up the ls1 flexplate and it have a gap between the transmission and the block does the lq4 short block have the spacer on it self have anyone got the 6L install on F body w/ automatic
ok i figure it out already...if anyone having this trouble the 6L crank shaft have a spacer all you do is get 2 bolt and bolt it in the 2 hole that offset and turn it clockwise and it will work with ls1 flextplate and bolt right in 4l60e tranny
