Why should I switch from the TRex to the MS4?
Old Aug 10, 2006 | 05:35 PM
fastGBcamaro's Avatar
Default Why should I switch from the TRex to the MS4?
I just ordered a set of Stg 1 LS6 heads from TSP. I am planning on replacing the lifters, and maybe the cam. Is there any benefit for me to put in the MS4 or should I stay with the TRex thats in the car now?
Old Aug 10, 2006 | 06:12 PM
import slayer's Avatar
stay with the rex
Old Aug 10, 2006 | 06:54 PM
SVT THIS's Avatar
The MS4 may have slightly less bucking issues. The MS4, which has more lift due to the LSK lobes, may have an advantage of power under the curve. However, with a 4000+ stall power under the curve should have zero meaning to you. Buy a hefty shot of N20 or mill the heads and flycut the pistons for the same price.
Old Aug 11, 2006 | 02:24 AM
ThirdGenLS1's Avatar
i see no reason to change from the rex to the ms4
Old Aug 11, 2006 | 10:30 AM
Default good idea
I like the sound of adding at least 100-150 shot of N2O to my set up. That would be a lot more fun. Thanks for all the advice so far. If the TRex isnt damaged from the collapsed lifter then I am probably going to stay with that. I still havent seen any dyno or track results for the TRex with heads. As soon as I get mine running I will have both shortly after.
Old Aug 11, 2006 | 01:35 PM
Photochop's Avatar
Got some numbers for ya.
My cam is a 'trex' (almost identical, lift is slightly higher), see sig for specs and numbers.
I'm going to try and get some weight out of the car and hit the track again when it cools off some and hopefully get some better track times.
Old Aug 11, 2006 | 04:10 PM
SVT THIS's Avatar
There's a guy on here with a heavy *** convertible, TRex and ETP 215 heads in the 10s. He's running 456 gears. Just make sure you have all the supporting mods (suspension, tires, bolt ons, valvetrain, gears, stall) or you will probably end up being very disappointed.
Old Aug 11, 2006 | 05:08 PM
Geoff's Avatar
A LOT of the bucking issues are tune related. If tuned properly the TRex can drive like a kitten.
 Michael S. Palmer
Old Aug 11, 2006 | 05:39 PM
01350ss's Avatar
^yup! trex and 4.56 spooled car drives amazing! No surging or bucking, stalling or anything like that. The drives so smooth yet extremely fast for what i have!!
Old Aug 11, 2006 | 07:00 PM
HOSS's Avatar
Geoff hit it right..my car drives like stock..except with a lil more kick in the ***
Old Aug 12, 2006 | 03:18 PM
Default keeping TRex
Thanks for the posts guys, I cant wait to see how my car runs with those new heads. I was already trapping 116mph with a bad tune and high temps. I am running a spooled 12 bolt w/ 4.30s a few suspension components and a 28x11.5 et drag so I am hoping that this is a pretty insane combo. Do you think I could see 120mph NA?
Old Aug 12, 2006 | 03:26 PM
SSilverSSurfer's Avatar
i dont see why not, i went 115 with an auto and an S cam(similar to MS3), get rid of the cam so you can sell it to me, lol
