Checking Your Work Before Install
Old Aug 14, 2006 | 10:20 AM
su_maverick's Avatar
Default Checking Your Work Before Install
Ok, so I have never actually run my engine. I bought a used engine and started my build. I am almost done with the build but would like to test it as best I can before installing it into the car.
What are somethings I can do to test the engine's functionality (aside from an engine dyno) in my garage before dropping it into my car?
Thanks!
Neal
Old Aug 14, 2006 | 11:14 AM
ShevrolayZ28's Avatar
If you've modified anything it's always a good idea to check piston to valve clearance and lifter preload.
Old Aug 14, 2006 | 11:15 AM
I use some clay for the piston/valve clearance but how do I check preload?
Old Aug 18, 2006 | 10:08 AM
The easiest way is to use a pushrod length checker.
Old Aug 18, 2006 | 10:48 AM
gotcha, thanks!
