408/402 swap question
Old Aug 14, 2006 | 04:27 PM
SVT THIS's Avatar
Default 408/402 swap question
I'm going to be building an FI motor soon and am trying to debate between a fully build 346 or a 408/402 sized motor. When doing an LS2 402 or LQ9 408 swap, will the accessories swap as well? By accessories I mean AC, P/S, alternator, starter, etc. Or, will I need to buy all new accessories as well? What about the wiring? Does it just wire up or will I need to get a modified harness? Thanks
Old Aug 14, 2006 | 04:34 PM
98Z28CobraKiller's Avatar
Restricted User
The 408 is a direct replacement.
Old Aug 14, 2006 | 05:36 PM
xaon's Avatar
all of those external accessories will bolt right over for either combo.
For the Aluminum LS2 block (402), i know you will need some new knock sensors and some extended wiring harnesses... possibly new covers as well?? I'm not 100% certain on exactly what is required when using an LS2 block in an f-body.
Old Aug 14, 2006 | 07:21 PM
ArcticZ28's Avatar
You will need to tap another hole for the alternator on the 40x block.
