mains torquing sequence...
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
Crankshaft Bearing Cap Side Bolts 18 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees
thats on LS1howto.com. i couldnt find the sequence im suppose to go in though
http://img226.imageshack.us/my.php?i...oltseq1cc2.jpg
