28000 Miles.. headgasket failure?
Old Aug 15, 2006 | 02:34 PM
amit's Avatar
Default 28000 Miles.. headgasket failure?
is it possible to have a head gasket go at such low miles?
Old Aug 15, 2006 | 02:36 PM
Michael02hawk's Avatar
Of course its possible - anything is.
If you have a head gasket failure, I'd say its more related to the time period...your 2000 SS might only have 28,000 miles, but it is 6 years old.
Old Aug 15, 2006 | 02:40 PM
amit's Avatar
but head gaskets dont blow at such a young age... do they? has there ever been a case in the ls1 world?
Old Aug 15, 2006 | 02:53 PM
Keenov's Avatar
Anything is possible my friend. Now is your chance to slap some new heads on there
Old Aug 15, 2006 | 02:54 PM
amit's Avatar
when i drive teh car for long periods of time the car gets too hot and coolant starts spilling out of the overflow tank. theres no leaks in teh system, changed the stat, rad cap, and did a rad flush. i doubt its the coolant temp sensor as the car runs perfectly fine. both of the fans work..
Old Aug 15, 2006 | 03:32 PM
Ditmeion's Avatar
Could be the reason why your head gasket blew...overheating will significantly reduce head gasket life....I suggest you find out why it is overheating, or you will destroy your new head gaskets after you replace them. Did you remove that plastic air deflector thing underneath the car?
Old Aug 15, 2006 | 03:56 PM
amit's Avatar
no
i put a gas analyzer in the overflow tank and the HC was nothing to be worries about.
