Using a truck LM7 intake on 408
Old Aug 15, 2006 | 03:35 PM
Stroker2112's Avatar
Default Using a truck LM7 intake on 408
Guys,
My 408 project has hit a snag...my budget has basically evaporated...I have everything but a new 90mm TB for my engine...so I'm sitting here at work contemplating whether to wait on the TB or just go home, bolt on the stock intake, drop the new engine in, and tune it up at the shop to see how she runs..... I have the following:
408 iron block
LS 243 CNC'd heads
forged crank, rods, & diamond dished pistons
Torquer2 cam
10:3 SCR
7.95 DCR
.041 quench
true dual exhaust
Should I wait for the 90/90 set-up?..
or
drop the stock intake/TB setup in and start driving? How much power will I lose by using the stock Intake and TB with above set-up vs 90/90?
Stroker2112
Old Aug 15, 2006 | 03:55 PM
RaNsOm's Avatar
That torquer2 cam is gonna be pretty small in a 408, and the truck intake will make great power down low, but the long *** runners will kill top end power.
Old Aug 15, 2006 | 09:34 PM
ArcticZ28's Avatar
Why so low S/DCR?
Old Aug 15, 2006 | 10:18 PM
Mssingkid's Avatar
Originally Posted by ArcticZ28
Why so low S/DCR?
I was wondering the same thing...
Old Aug 18, 2006 | 11:48 AM
I don't believe I have adequate P/V clearance with a .040 head gasket ( I did the clay tests several times and thought the results were too close, like around .060 - .080.....so I went with a .051 cometic head gasket for extra insurance. Don't get me wrong, I'd really like to have better S/DCR values but don't think I have a choice without doing something major at this point...
What would you recommend?
Stroker2112
Old Aug 18, 2006 | 11:59 AM
SStrokerAce's Avatar
I don't know how with forged DISH pistons and that small of a cam you are having any P to V problems..... maybe the pistons are in the motor backwards?
Bret
Old Aug 18, 2006 | 12:45 PM
funny...but no. The heads are milled too... (.015 which isn't that much). How much of a reduction in performance am I really sacrificing by reducing the DCR from 8.3 to 7.9 with the bigger gasket? I mean, I could take a chance and run the tighter quench...but for a daily driver...do I really need to?... I'll probably lose what...10hp?...
Stroker2112
Old Aug 18, 2006 | 12:58 PM
98RedZone's Avatar
Do you already have the intake but no throttle body?
Old Aug 18, 2006 | 01:13 PM
ArcticZ28's Avatar
It's not about just losing horsepower, it's about losing area under the curve and driveability with a slacking DCR.
Old Aug 18, 2006 | 02:15 PM
Yes, I have two intakes (truck and LS2) to choose from...stock TB works with the truck intake only....I have to wait until my budget improves before I get the 90mm/LS2 TB.
So, I guess I'm at the point of either putting it all together with what I have....or waiting and taking some risks with the .040 gasket later.....what would you do?...If I knew how much the lower DCR actually affects the performance it would be easier...
