How to wash engine
Old Aug 18, 2006 | 07:18 PM
ls1greyhound's Avatar
engine degreaser and then use tire wet on the intake and air lid. I do it once a year and get compliments on my engine bay all the time.
Old Aug 18, 2006 | 08:52 PM
z-ya's Avatar
I piont it towards the mississippi at 90 or so.
Old Aug 18, 2006 | 08:58 PM
Gearhead1's Avatar
I tried that once but I just skipped across the water.
Old Aug 18, 2006 | 09:45 PM
11 Bravo's Avatar
Simple Green. Works much better than engine degreaser.
Old Aug 18, 2006 | 09:47 PM
ArcticZ28's Avatar
What about Simple Green "MAX" though?
Old Aug 19, 2006 | 02:51 AM
Grimes's Avatar
concentrated simple green on a warm engine, let sit for ten minutes, then rinse with a mild stream of water. As mentioned before, make sure to rinse the simple green all off. I have done this twice in the last couple years, and my engine looks like new. Stay away from the pcm harness....
Old Aug 19, 2006 | 05:27 AM
ShevrolayZ28's Avatar
Some info on use of Simple Green:
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
http://industrial.simplegreen.com/ind_faqs.php
