head gasket question
Old Aug 16, 2006 | 02:26 PM
Crittpen's Avatar
Default head gasket question
I am thinking about running the gm mls style gasket, i have heard that peaple are having problems with cosmetics under boost.
i am going to be runing about 10 to 12 psi i have a set of wisco blower pistons that are 3.905
will i still be able to run the gm mls gaskets with this bore size?
is there somthijng else you recomend besides the gm's?
i will be running either ARP studs or bolts
most likly studs if i can budget for them
thanks for any help
Old Aug 16, 2006 | 07:49 PM
smask04C5's Avatar
Cometics are excellent, as long as deck and heads are flat and clean. Used same set on afr heads on vette in sig, no issues. Granted, N/A but you'll be fine with 10-12 psi boost. Plus, you can order specific hole diameter and thickness from Cometic also.
Old Aug 16, 2006 | 07:52 PM
viewsonic's Avatar
I used some copper spray on my cometics
Old Aug 16, 2006 | 08:00 PM
smask04C5's Avatar
Agreed on the Cu spray
