2001 Vette motor
Old Aug 17, 2006 | 01:25 PM
dedge's Avatar
Default 2001 Vette motor
My 98's LS1 spun the rod bearing. I looked around and bought one of MIZFIT Motorsports 2001 Vette crate motors. I was going to take the Torquer V2,pushrods,spgs,tit. retainers,and crane double roller gear set off the 98 and transplant it all over to the new motor. Should I expect any significant HP gains this. I know the 98 Ls1 was rated at 305hp and this crate motor is rated at 350 hp from GM.I know they used the LS6 block on these motors. I was wondering if their was any real difference in the heads.I know the Ls6 intake is worth at least 20 hp anyway.
Old Aug 17, 2006 | 09:28 PM
HeapaShifter's Avatar
The heads flow better and the intake flows better. I'd say about 20 hp is possible. There's a sticky somewhere that tells all the differences.
Old Aug 17, 2006 | 09:32 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, that is flywheel horsepower. You will see around 375-390 most likely with that cam.
