6.0 Head gaskets..
Old Aug 17, 2006 | 01:32 PM
dirt track racer 81's Avatar
Default 6.0 Head gaskets..
Im building a 6.0 with 241 heads. I'm just trying to figure out what heads gaskets i should go with??
thanks
Old Aug 17, 2006 | 01:56 PM
Quik's Avatar
use gaskets that match the block not heads. and your wasting youir time with heads that flow less then the stock 6.0s. the gain you get in CR isnt enough to make up for loss in CFM
Old Aug 17, 2006 | 02:03 PM
GuitsBoy's Avatar
I agree. The stock 6.0L heads have the same port design as ls6/ls2 #243 heads. Consider having them ported out at least. But yes, you would need the 6.0 gaskets, as the 5.7 gaskets would hang into the cylinder and burn.
Old Aug 17, 2006 | 03:47 PM
ive already got one head ported, im going to start on the other head tonight..since this is the lq4.. should i have these heads milled??
