I have a question. about doing a heads and cam package.
Old Aug 21, 2006 | 04:36 PM
Travose21's Avatar
Default I have a question. about doing a heads and cam package.
I got over a 100,000 miles on my motor. and i wanna do a heads and cam combo. do i have to change plenty of things in the motor. I wanna go with a thunder racing 224 cam and LS6 ported heads. can i get that with a motor that have over 100,000 miles. let me know yall sugesstions. PLEASE
Old Aug 21, 2006 | 04:58 PM
8GTOKLR's Avatar
If you have a concern about milage when doing the swap have a shop do leak down and compression check to make sure you're not wasting time and money.
A few things you'll need in my opinion:
head & cam gasket kit
New Timing set that has new cam and crank sprokets
sparkplugs
New valves & spring kit
Head Bolt Kit(2) (or use Arp stud kit),
Balancer bolt
('01-'02 )28.8# Injectors or bigger
Depending on how old LS6 intake is some new O ring gaskets for it
and ofcourse some Good Oil
That should get you close im sure someone else could add
Old Aug 22, 2006 | 11:31 AM
Travose21's Avatar
ok. because i want the heads and cam. you can read my mods, my car run hard to be stock. just full exhaust and ported tb. i was sugessting that i do a heads and cam
Old Aug 22, 2006 | 03:43 PM
8GTOKLR's Avatar
I re worded, sorry for confusion. And add lifters too list
Old Aug 22, 2006 | 07:55 PM
Travose21's Avatar
ok thanks thats all
