Build Question
Old Aug 24, 2006 | 10:39 AM
STKN1STGEAR's Avatar
Default Build Question
I have an 99 LS1 That needs to be rebuilt. It has a vortec 9PSI supercharger w/ aftercooler. 50K miles. I'm looking for around 500RWHP and good streetability.
What will be the best and cheepest way to rebuild this?
Old Aug 24, 2006 | 11:38 AM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Well, probably forged pistons and rod bolts will be your major expense. What part needs "rebuilding"?
Old Aug 24, 2006 | 12:17 PM
I have melted #7 piston. It still runs but blows a lot of smoke.
Old Aug 24, 2006 | 12:46 PM
With the supercharger I have to stay under 10.5:1 yes?
Does it mater what cam I put?
I want streetability and smooth throtle responce.
So if I go with forged pistons and a mild cam, will that work with the supercharger?
What cam do you recommend?
Old Aug 24, 2006 | 12:54 PM
ЯєŧąяĐ Єlˇmˇиąŧřя ™
I would recommend calling Comp, Thunder, TSP, or SDPC and get a good custom grind for that combo. Not just any old cam will work with a supercharger very well. Granted it will run and still probably a pretty nimble machine. Custom grinds are the way to go. I would talk to the experts and get their advice. Some people would say to go with the LS6 cam or Z06 cam because they work well with a boosted application such as you are doing.
You should be able to street that thing with no problems, but you are gonna want a really good tune to have it be well-mannered. You can lower your compression ratio and up the boost with the right kind of piston too. this is a pretty good way to get some serious power. Like a -12 or -15cc relief would lower your stock ratio down into the 9's possibly. Also matters on what type of gasket you chose to run too.
Basically you have a lot of potential to make that thing a regular DD/Street Machine.
You might want to consider rods too and call it a forged shortblock.
Just my $0.02 on what I would do if I were you. Hell you already have the supercharger. that is the expensive part of making power right there.
Old Aug 24, 2006 | 03:01 PM
Cop Car's Avatar
you should drop your compression this time so you can run higher boost #s, 500rwhp would be easy to do with a blower and forged pistons
pick a combo that will put you about 8:1 (i belive is the best number) you might want to look into a diffrent head at the same time, like a ported LQ4, they have a bigger combustion chamber in the head (drops compression)
as for cam, get a forced induction oriented cam, my suggestion would be to post this stuff in the forced induction section of the forum
Old Aug 24, 2006 | 03:02 PM
Thanks for the advice. I still have to think about this some more.
Old Aug 24, 2006 | 03:06 PM
I don't understand why everyone is telling me I should drop the compression?
The stock compression is only 10.5:1.
As for the ported heads, I thought that if I run ported heads with FI it would cause problems with lag in the mid range? sure you gain at the high end but this is a street car.
