Oil Pressure Little Low!!!!
I'm seeing the same thing, but my car has almost 100xxx miles on it with the stock pump.
Did you at least upgrade the oil pump when you had the heads and cam put on?
If not, I'd suggest looking into a ported ls6 pump.
Resistance to flow creates pressure, i.e. thicker oil many times = higher pressure. Main bearing clearances are a large contributor to oil pressure. More wear on the motor, lower oil pressure. Looks like you have a 98', the earlier years of the LS series have a bad reputation for catastrophic oil pump failures, so you might want to have a replacement pump handy.
