View Poll Results: Which Cylinder head is best FOR THIS SITUATION ???
TSP PRC LS6 w/ competition valve job: $1200ish
9
20.45%
TSP 200cc Terminator heads: $1900ish
7
15.91%
AFR 205cc: $2100ish
13
29.55%
TSP stage 2 ported DART heads: $1600ish
0
0%
Patriot ls6 style heads: $1300ish
7
15.91%
OTHER???
8
18.18%
Voters: 44. You may not vote on this poll
Help me pick out some cylinder heads!!!
Old Aug 28, 2006 | 11:34 PM
ShevrolayZ28's Avatar
Originally Posted by will82
Also, take price into consideration.
Oh come on! It's a Corvette! Get the best.
I'd get either AFR, ETP, Trickflow, or Edelbrock. Does that narrow it down at all.
Old Aug 29, 2006 | 04:24 AM
BOWTIE's Avatar
No matter what heads I get, I do want the best springs b/c like I said, in the future I will swap cams, probably a CheaTR (high-lift #s) because my ultimate goal is FI in the next 2 years.
I do not believe the AFR's come with an equivelant spring then. That would require an upgrade on their heads. Granted I am not sure that would be needed with that cam but you may want to check into it.
Old Aug 29, 2006 | 08:05 AM
LSX-Racer's Avatar
Banned - Ed Curtis aka EDC
Pretty much every 1.290 diameter dual spring out there is the same part number Associated/Pioneer spring. Some shops say they're good to .600" lift and others say .650" lift. Guess it depends on who you buy them from. So, if comapny "A" says you can use them for this cam, and company "B" doesn't, it must be their own personal experience.
Old Aug 29, 2006 | 12:52 PM
BOWTIE's Avatar
Well with out having the springs to compare and never having heard that before, I am not sure I would buy that. What I do see is that AFR recommends you UPGRADE from the 8017's (which their heads come standard with) to the 8019's if you plan on running over .600 lift or over 6600 rpms.
Old Aug 29, 2006 | 01:43 PM
Patrick G's Avatar
LS1 Tech Administrator
With all the bolt-ons you have and your desire to keep your ride very streetable, I vote AFR 205s all the way. I can't begin to say enough about the crisp throttle response they give over stock heads. Increased fuel economy too. Most ported heads give up crisp throttle response vs. stock. Not the AFR 205s. I speak directly from personal experience having run 6 different ported heads in my various LS1 F-bodies. Nothing has even come close.
I find it funny that many people are voting for a head they have no personal experience with...
I can say with conviction that if you want better than stock throttle response, better than stock fuel economy, 40-50 rwhp gain, and strong resale value if you ever decide to go on to a different project, go with the AFR 205s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 29, 2006 | 06:38 PM
LSX-Racer's Avatar
As I stated, they use the same spring. Some get them coated or nickel plated but it's the same spring. Some play it safe while others tend to push the limits of the particular spring.
The part number is Pioneer 053658x quantity.
It's not an industry secret.
Old Aug 29, 2006 | 10:16 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
You make a very convincing argument. If I went with AFR205 with standard sized combustion chambers, would it be possible to have work done later to increase the combustion chambers to 76cc for FI, or would I have to buy new heads? Or, could I go ahead and run 76cc chambers N/A and see close to the same power increases?
Old Aug 30, 2006 | 06:21 AM
Adam_346's Avatar
I'd go with Air Flow Research.
Old Aug 30, 2006 | 08:12 AM
Patrick G's Avatar
You could do it, but it would be very involved and very expensive. You'd basically have to open up the combustion chamber and sink the valves to gain the extra chamber room. Both take a lot of labor if you plan on keeping the dual quench pad and high flow valve seat arrangement intact. A better plan would be to sell the AFR 205s (strong resale value) and get the AFR 225s in the 72cc chamber size or keep the 205s and buy a dished forged piston. With forced induction, a stronger piston is always a good idea.
__________________
