Smoking and pushing coolant out.
Old Aug 26, 2006 | 03:28 PM
03BlackWidow's Avatar
Default Smoking and pushing coolant out.
I just swapped headgaskets on my car w/ a fel pro mls set, I already had 12pt head studs and the heads were just milled for a good surface. I started the car and let it run and its still smoking and pushing coolant out of the exhaust like before. I thought it blew the headgaskets before but now think the heads are messed up.
Their stock LS1 heads that were ported and then epoxied. The work was all done when i bought the car and dont know who did the work. Does it sound like the heads and am I better off getting these fixed or getting new ones. These heads have LS6 valves and good valve springs so id hate to ditch them to spend a fortune on good heads.
Old Aug 26, 2006 | 03:42 PM
calongo_SS's Avatar
I'd get them pressure tested, sounds like one may be cracked, or more likley the porter got into a water jacket. Might be able to fix it with epoxy.
