Building a 98' Block What oil pump?
Old Aug 31, 2006 | 10:13 PM
MiaSSmaro98's Avatar
who was the supplier
Old Aug 31, 2006 | 10:18 PM
who was the supplier?
Old Aug 31, 2006 | 10:33 PM
Slo_240sx's Avatar
Okay so maybe I shouldnt try to port mine on my own?
Good stuff kevin, they'll treat you good there and dyno it in house. My car will be done around the same time yours will be done so you better be able to hand me my ***!
Old Aug 31, 2006 | 10:54 PM
BlkHwk's Avatar
Steve @ RED did my MID Sleeve install and the porting.
Old Sep 1, 2006 | 07:40 AM
777's Avatar
777
My bad guys, I had never heard of the actual block having oil problems until now. Learn something new every day.
Old Sep 1, 2006 | 11:06 AM
LS1Beginner's Avatar
On my 98 I used the SLP double roller chain and oil pump kit with the higher pressure spring. Car sees limited WOT (street), oil pressure is solid @ 58PSI, no problems yet.
The kit was an easy install.
Old Sep 1, 2006 | 12:41 PM
blkhwk weres red located at?
Old Sep 1, 2006 | 04:13 PM
BlkHwk's Avatar
Race Engine Development
He's a sponsor here.
Old Sep 1, 2006 | 10:04 PM
any clue what it will cost to have that oil passage done?
Old Sep 2, 2006 | 07:10 PM
BlkHwk's Avatar
I can't say on the cost. I went through Mizfit to get the block and some other stuff. It was kind of a package deal you might say. Could contact Steve and ask.
The Melling pump worked fine with the dual rollmaster. Used the spacers that came with the chain. Had to clearance the pump slightly near the suction port. The casting is slightly larger than the stock pump in that area.
I am pretty sure I will have to do some clearancing on the front cover but haven't gotten that far yet.
