How to block the intake holes ( EGR)
Old Aug 27, 2006 | 11:01 AM
Ricky_GD's Avatar
Default How to block the intake holes ( EGR)
Hi, i need to block the EGR hole on the top of my Intake, has anyone done this before? if so how etc..
regards
Old Aug 27, 2006 | 11:04 AM
fast377's Avatar
rubber expansion freeze plug=cheap and easy.
Old Aug 27, 2006 | 11:05 AM
jermzz's Avatar
You need a freeze plug. 1 7/8 size if i remember correctly.
Old Aug 27, 2006 | 11:19 AM
Ricky_GD's Avatar
Where can i get one of those from? neaver herd of them. in England if possible
Old Aug 27, 2006 | 11:30 AM
fast377's Avatar
local parts store
Old Aug 27, 2006 | 11:33 AM
Ricky_GD's Avatar
bauer millett will they do it ? or any just parts store?
Old Aug 27, 2006 | 12:54 PM
Ricky_GD's Avatar
http://www.imperialinc.com/items.asp?item=0069790
somthing like that?
Old Aug 27, 2006 | 01:02 PM
bad86z28's Avatar
Same idea as that, but it is a thick rubber disk sandwiched by two metal plates. It has a threaded bolt that goes through the center with a nut on top so that as you tighten the nut, the two metal plates squeeze together and the rubber piece expands to fill the EGR hole. I'll see if I can find a pic.
Old Aug 27, 2006 | 01:06 PM
Ricky_GD's Avatar
yer if you could, i have neaver herd of these... anyone know of a web site that sells them>? can you comfirm thats its 1 7/8 ?
regards
Old Aug 27, 2006 | 01:10 PM
bad86z28's Avatar
The second to last post on the first page has a pic. https://ls1tech.com/forums/showthrea...ht=freeze+plug
Old Aug 27, 2006 | 01:17 PM
Ricky_GD's Avatar
so is it 1 3/8 or 1 7/8 ???
Old Aug 27, 2006 | 01:30 PM
V6 Bird's Avatar
WAAAYy too big.
Buy a 35mm metal freeze plug for .59 at oreilly's or Autozone and it LOOKS way cleaner then the stupid rubber freeze plug with bolt in it.
Old Aug 27, 2006 | 01:31 PM
V6 Bird's Avatar
Originally Posted by Ricky_GD
Yes...tap it in until it hits the plastic stops in the intake and you will be fine. That one looks the best IMO. the picture later in this post looks like *** when its installed. Doesnt look like it was supposed to be there like this picture.
Old Aug 27, 2006 | 02:50 PM
Ricky_GD's Avatar
arrr freeze plug core plug ?? same thing? if so thats what us brits called them
Old Aug 27, 2006 | 03:03 PM
Dipstick's Avatar
I machined a plug out of aluminum, but there are companies that make a custom billet block-off plate. Sorry, don't remember their name.
Old Aug 27, 2006 | 04:31 PM
Ricky_GD's Avatar
can anyone comfirm that your feeze plugs are the same as our core plugs?? and the size im reading a few different sizes,
regards
Old Aug 27, 2006 | 05:32 PM
Jake@EPP's Avatar
If you still looking for one we sell a billet aluminum block off plate that just bolts down in place of the tube. You use the 10mm bolt that was used to hold it down on the plate.
Old Aug 27, 2006 | 11:05 PM
jermzz's Avatar
That would be the easiest way to do it.
Old Aug 28, 2006 | 05:50 AM
Ricky_GD's Avatar
yes please more info...
