New heads and valve train setup?
Old Aug 28, 2006 | 06:33 PM
Doc99SS's Avatar
Default New heads and valve train setup?
I have a '99 Camaro SS with many engine mods. Currently, I have Mike Morgan Sport heads and I am going to replace them with newly acquired Patriot Perfromance heads.
I am planning on ordering the Comp Cams 13705 roller rocker arms (1.85 ratio) and install Comp Cams 26921 valves springs.
Also, replacing all of the hydraulic roller lifters with Comp Cams version (CC-875-16) and 7.4" long 5/16" push rods(CC-7955-16).
Does anyone see any mismatches here? I am doing the above due to multiple broken valve springs which started with the install of the Morgan Motorsport heads with their own valve springs, whereby the inner damper spring broke on about half of the valve springs. I have even broken one of the early 921 springs which were my replacement set.
TIA
