head gasket help
Which 6.0 head gasket should I use?
"the reason for using a 6.0 gasket on a 5.7 is the fire ring on a 6.0 gasket is matched to the o rings on the head,we had to do it this way to get a better seal the 5.7 gaskets fire ring is a few thousandths smaller diameter and would have been too close to the cobustion chamber for a o ring to work"
Not a large cam and stock compression is fine with me. Really would like a C/H install kit???? (or autozone)
Thanks
