Ms4
Old Sep 1, 2006 | 01:24 AM
c5_ls1_6spd's Avatar
Default Ms4
what are some of the numbers you MS4 owners are putting down? what combos??
Old Sep 1, 2006 | 02:24 AM
white98terror's Avatar
There probally isn't a lot of guys running the MS4 yet primarily because its fairly new . TSP claims 60+Rwhp over stock cam but this on a built motor i would imagine it will be up there because TSP is a reputable company and their cams are no slouch.
Old Sep 1, 2006 | 06:35 AM
300bhp/ton's Avatar
Originally Posted by white98terror
1998 Camaro A4 Stock Ported Heads, 228/232 591/604 114lsa Cam, Comp Cams Pro-Mag Rockers, LS6 Ported Oil Pump,BBk Intake, FAST 90mm TB, Ported MAF, Lid, Custom Ram Air, SLP Pulley, Taylor 9mm Wires,Smooth Bellows, Hooker Super Comp LT's, ORY, Magnaflow, Cutouts. 4L60E Stage 2 Rebuilt, TCI 3800 Stall, Transgo Shift Kit, Moser Axles, Locker, T/a Cover, BMR Suspension. 468rwhp/453ft/lbs.
!ALL THROTTLE NO BOTTLE!!!
Kinda curious how you got such high dyno numbers from your setup considering the mods listed and all on a auto??
What kind of ET and traps is it capable of?
Ta.
Old Sep 1, 2006 | 07:37 AM
JoeyGC5's Avatar
At TSP with 2ish miles on my new forged motor and PRC stage 2.5's my vette did 448rwhp and like 396rwtq. Local dyno in K.C. about two weeks later it did 390rwhp and 380rwtq, on 7 cylinders
If I can finish up the differential upgrades and get to a track by next friday you'lll see some track times. Otherwise won't be able to post any results until after Drag Week.
Old Sep 5, 2006 | 07:42 PM
Dub C's Avatar
I want to see some dyno graphs as well!!
Old Sep 5, 2006 | 07:49 PM
stealthair's Avatar
Just finished installing the MS4 in a T/A, waiting on the correct headers to come in so I can start it, will also post up dyno information as soon as i can
Old Sep 5, 2006 | 07:50 PM
ArrestMeRed99Z28's Avatar
here's a thread i found in the dyno section:
https://ls1tech.com/forums/showthrea...&highlight=ms4
