Nastiest cam....
Old Sep 2, 2006 | 10:19 PM
import slayer's Avatar
I think as far as drivability goes, a lot of it is in the tune I have heard that a lot of people DD a trex and have no complaints
Old Sep 2, 2006 | 11:40 PM
SSilverSSurfer's Avatar
Originally Posted by SilverSS
767/788 .904/.909 102lsa
thats too small, he wasnt nasty
why do you want the nastiest cam for a daily driver? you want the power to be usable right? i dont see you spending time in the 6500-8000rpm range driving your car everyday
Old Sep 3, 2006 | 12:02 AM
I could not have said it better myself lol
Old Sep 3, 2006 | 12:23 AM
SS4Matt's Avatar
don't forget about all the random BS you're gonna need to buy too...the '98 being the bastard year, gonna have to get some other stuff if you swap heads,
Coil brackets, centerbolt valve covers, water pump gaskets and PCV hose,
better get a different oil pump too. LS6 or something along those lines, a ported one.
you can get a lot of stuff for $6G's. if you are decent with a wrench, a heads/cam swap isn't that bad. i've done a few to mine now. and like that one sticky say's
it's all about a system. make sure everything works well with everything else, don't just blindly go out and buy the "biggest most expensive" everything.
Old Sep 3, 2006 | 01:50 AM
LFNDUST's Avatar
All these guys say read...I just searched on all the topics that I was interested about and I found all the info and a few guys helped out a long the way including orangepeel.
I found that I wanted to keep my stock heads for now...so this is what I went with...
Cam :
230/236 .598/.598 111 lsa
Springs:
REV 1116 or Patriot Gold Duals
Oil Pump:
LS6 Oil Pump
Timing Chain:
LS2 Timing Chain
Push Rods:
chromoly 7.400 (stock length)
Exhaust:
Hooker LTs, magnaflow true duals.
Thats me my buddys car with the same cam, but he had heads was pushing 475rwhp. (with a good tune) so we'll see where I'm at with stock heads.
Old Sep 3, 2006 | 12:11 PM
black97ss's Avatar
i basically drive this everyday.. and this is the list of mods i got not very legal but its still a lotta fun... not very friendly but i still drive it all the time
MOTOR MODS
-5.7 LS1-Bored 35 over-TREX Cam - ReX v.2 - 242/248 - .608/.612 - 110 lsa
-Heads were ported stage 2 - 2.02"/1.60"-LS6 Intake-Mahle forged pistons 3.905"-Callies Rods-ARP Rod Bolts-ARP Main Bolts-Clevite Bearings-LS2 Timing Chain-LS6 Oil Pump-ARP Head Studs-REV Valves-Patriot Dual Springs-Titanium Retainers-Super Seven Locks-MTI Pushrods-Bronze Valve Guides-TR55 Plugs-Taylor Thundervolt Wires-Rings are gapped for a 200+ shot of nitrous-Underdrive Pulleys-Ported Throttle Body-Carbon Fiber Air Intake Lid with K&N
DRIVETRAIN MODS
-Stronger Rebuilt 6 speed-B&M Shifter-Poly Transmission Mount-Denny's Nitrous Ready Drive Shaft-Moser 12 Bolt-4:10'S-Auburn Differential-33 Spline Axles-Slotted and Cross Drilled Rotors-Willwood Brakes-BMR Torque Arm-BMR Lower Control Arms-Subframe Connectors-Hotchkis Panhard Bar-Eibach Drag Springs-Skip Shift Eliminator
RUBBER and RIMS MODS
-Torque Thrust 2's 17x9.5 in front and 17x11 in rear
-Nitto 555R street Drags in rear
-Kumho Ecsta Supra in front
EXHAUST MODS
-Hooker long tubes
-3" X-pipe (True Duals)
-3" Sweet Thunder chambered mufflers
Old Sep 3, 2006 | 01:36 PM
98Z28MASS's Avatar
Originally Posted by MonsterZ28
Its a DD, by nastiest cam i meant nastiest one my car can handle.. what heads will go with a t-rex cam? and 98z28 mass, that sounds like alot of ****, that will all be under 6000?
If you can do most of the installs yourself then yes. Dez racing supplied me with my 232/238 cam, hardened pushrods, dual valve springs, titanium retainers, ls2 timing chain, powerbond 25% underdrive pulley, ported my stock throttle body, and installed the following (which I brought): bilstein hd's on slp springs, ls6 intake, new rotors and pads, ls7/ls2 clutch/flywheel combo, weld in subframes, adj panhard rod, lower controll arms, gutted my stock cats, and dyno tuned the entire package for $3300. So figure $3300 for the cam kit, instllation of all those parts, and dyno. Then the parts above:
ls6 intake = $400 new from slp online
bmr 2 point weld in subframes = $150
UMI lcas = $100
UMI adj panhard rod = $100
bilsteins and springs = $500
rotors and pads = $300
since you dont need the clutch then figure:
4000 stall = $500
B&M tranny cooler = $300
pacesetters + ory = $500
magnaflow = $400
so 3300 + 400 + 150 + 100 + 100 + 500 + 300 + 500 + 300 + 500 + 400 = $6550
So yes it can be done and if you already have som eof thos eitems then it will be even less and the only things I installed myself were my headers and y-pipe, everything else was done by dez racing. If you install a lot of the stuff by yourself you could probably do the job for around $5000 or so and you would be looking at around 400+ rwhp cam only and have a sick drag setup that will work great on the street.
Old Sep 3, 2006 | 11:10 PM
my rev duals went to **** so quick, i would stay away from those, patriots should do fine
Old Sep 3, 2006 | 11:50 PM
ZL1Killa's Avatar
Hey guys i need a little help, i have about 6000 to spend on my stock 98 z28 A4...
Whats the biggest cam i can get.. can i get full bolt ons, a h/c stall, and install for around 6 or under or am i just dumb for thinking it? and can you guys guide me in the right direction
go big...but don't you want to make power? the biggest cam isn't necessarily the most power maker.
Old Sep 3, 2006 | 11:56 PM
~JOSHUA's Avatar
Don't go higher than 23x on the duration and you won't hate yourself in the future.
Old Sep 4, 2006 | 04:07 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That's cause he rules.
Old Sep 4, 2006 | 01:28 PM
  #32
8banger's Avatar
I started off with a stock 99 A4. I'm not done yet, but I can tell you exactly what I would do if i did a whole setup at once. Read up on doing the installs and do them yourself. That's what I did and everything has been turning out perfectly. I went from not even knowing how to change my own oil to doing headswaps myself.
LS6 intake = $330
Ported throttle body = $50 + original
Dart 205's = $1200
G5X4 cam (good dyno AND track numbers) = $400
160* Thermostat = $40
Edelbrock headers/ORY = $600
Hooker catback = $330
Fuddle 4000 stall = $400
TransGo shift kit / B&M Tranny cooler = $150
Motive 3.90:1 gears = $220
UMI LCA's/PHR = $165
UMI Torque arm = $350
UMI subframes = $150
QA1 springs/shocks = $350
Drag radials = $300
Total: $5035
Old Sep 4, 2006 | 01:36 PM
  #33
TheCarKid's Avatar
I daily drive my Trex. It puts up a lot better numbers with my mods than what i have posted, but hell that was only on 7 cylinders before my rebuild.
Old Sep 4, 2006 | 01:50 PM
  #34
2 Stroke Racer's Avatar
Who the hell let out my cam spec's??????????
Old Sep 4, 2006 | 01:58 PM
  #35
LFNDUST's Avatar
pretty much huh...but yeah...I say if you going to put a cam in...put something in thats going to get you good numbers and a rough idle...whats the point to get one that idles smooth hahhaha
Old Sep 4, 2006 | 03:21 PM
  #36
Beasst8's Avatar
I got one of those in my saturn. hehe
Old Sep 4, 2006 | 04:00 PM
  #37
SDMForever's Avatar
Cam isnt everything if you got the cash do a stroker setup. the biggest cam is not always the best its an overall package.
Old Sep 4, 2006 | 04:32 PM
  #38
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well that is the difference between 300-700 $ vs. 3900.00-7500.00 $.
