pushrod length????
Old Sep 3, 2006 | 02:42 PM
erikthegoalie's Avatar
Question pushrod length????
I am going to throw some terminator heads on with an MS3...I have some hardened PR's from texas speed, stock length 7.4 i believe..
will that need to change with my new set up?
I would hate to have to sell the ones I bought..
Erik
Old Sep 3, 2006 | 02:46 PM
PREDATOR-Z's Avatar
TSP uses those but I would use at least 7.425
Old Sep 3, 2006 | 02:50 PM
you think so??what would the advantages be
What happens if I use the stock length...
erik
Old Sep 3, 2006 | 03:02 PM
PREDATOR-Z's Avatar
yes i'm sure, Why because you'll get a tighter preload. 7.40's will have added valvetrain noise due to loose preload.
let me give you an idea, I run 5.3 heads milled .025 with .050 gasket on a XE-R .59x lft and I use 7.40 without a peep from the valvetrain.
That is .025+.004= .029 mill effect.
Had it been with stock gasket, unmilled I would run 7.425's (which i used to on old setup)
Old Sep 4, 2006 | 06:37 AM
cool i see thank you Sir
Anyone else got any 411 on the subject
Old Sep 4, 2006 | 12:05 PM
LS1Beginner's Avatar
I am running Harland Sharp 1.8's with Patriot heads and ~.600 lift. Was told that these rockers require a slightly shorter pushrod. Did a pushrod measurement and sent to Smith Bros.. They put .045 preload which worked out to a length = 7.350. My valvetrain is very noisy. I intend to put the 7.4's back in. Things are OK at 4,000+ but at idle it drives you nuts. Live and learn.
Old Sep 4, 2006 | 12:09 PM
PREDATOR-Z's Avatar
.045 preload is too light, stock preload is close to .100
From my experience, I setup at least .080 cold
