Boost + stock bottom end = ?
Old Sep 4, 2006 | 11:08 AM
justind's Avatar
Default Boost + stock LQ4 = ?
Just picked up a '03 LQ4(iron block 6.0) this weekend and I was kinda wondering how much boost the stock stuff could handle reasonably?
Old Sep 4, 2006 | 11:56 AM
PREDATOR-Z's Avatar
Well if you replace rod bolts with Katechs, you could run close to 10psi. anymore and it becomes an issue with the pistons and rings.
meth injection helps with FMIC
Old Sep 4, 2006 | 01:22 PM
67Firebird455's Avatar
I agree, about 10# is the limit, should run great even at that amount of boost on that motor. You push it too hard, pistons start coming apart, believe me, I broke 3 of them.
Old Sep 4, 2006 | 01:35 PM
Cop Car's Avatar
because its an LQ4 it has low compression. 8:1 i think. stock LS1s have held 10 psi no problem, and thats with 10:1 compression. there have been several guys who have pushed stock LS1 bottom ends past 15psi.
my guess is that with that low compression ratio you could proably see 15-20 psi alright.. but thats just my guess. you should post in the force induction section, thats what its there for. ringlands will give up before anything else. but you should get rodbolts for sure, expecialy since the motor is out of the vehicle right now and its something hard to relace with the motor in the car.
Old Sep 4, 2006 | 02:00 PM
The LQ4 I believe is right at 9.4:1. No way could you consider running 20psi. If it's really 9.4, with a good tune and meth/FMIC you could run 12-13 without blowing it up.
Old Sep 4, 2006 | 02:36 PM
justind's Avatar
Yeah I was trying to decide whether I should post here or the FI section. Thanks for the help. Oh and by the way this is going into an airboat not a car.
