My Stroker Idea
Old Sep 5, 2006 | 07:25 AM
Nikon02's Avatar
Default My Stroker Idea
I plan on doing a 3rd gen swap and am starting the buying process. I was thining of this for a daily drivability motor setup. Do you guys think it would work for daily drivability? how much power do you think it would produce? good combos? or should i just go with an iron 6.0L block and build that up to a 408 with similar cam and head setup?
Heads
Stage II 1020 Superflow Bench 3.905 Bore
2012 Bare 2.02"/1.57"/64cc
CAM
DUR @ .004" 284*/284*
DUR @ .050" 216*/222*
LIFT .531/.531
OVERLAP 56*
LSA 114*
Lunati 383 stroker kit
Stroke Rod Length Dome Bore CID Compression Ratio
4.000 6.125 +5cc 3.903 383 12.5
Old Sep 6, 2006 | 06:05 AM
Nikon02's Avatar
Someone please help out with this.
Old Sep 6, 2006 | 07:09 AM
11 Bravo's Avatar
It would be a good daily driver with that baby cam. How much power with a 216/222 I have no idea. Never seen a cam that small in a 383.
Old Sep 6, 2006 | 09:26 AM
Cop Car's Avatar
lunati kit is something like 4k. insane.
LS1s are overpriced IMO. get a motor out of a truck. but keep in mind that you would then have to put the oil pan, water pump, intake off an LS1 on it and probably also LS1 accessories. you can get a low milage LQ4 (6.0) for $1300, and a 4L60E for $600-$800.
Old Sep 6, 2006 | 09:42 AM
silver01z06's Avatar
that cam seems very small for a lsx based motor.
Old Sep 6, 2006 | 03:02 PM
Nikon02's Avatar
What would you recomend for a cam then?
How mig (even for a DAILY DRIVER) should i go with a 383? 408?
Old Sep 6, 2006 | 06:31 PM
magius231's Avatar
first note that daily driver means different things to different people...I drive a LT/true duals car around that lots of people would consider way too loud for the street, people drive around TRex/5000+ stall/4:10 gear cars which people would consider undriveable, and they love it.
you can pick up a forged 402 short block (with a warranty) from many of our sponsors for around $4-$5k, get a good head/cam/intake setup for around another $5k, and make 500-550rwhp easy. Or, keep your stock displacement, put a budget heads/cam/intake on it, and make around 420-440rwhp for around $4k (including bolt-ons). On the extreme end, you can pick up an LS7 crate motor for $14k, have some of our vendors work it over for around another $8k, and end up with 630+rwhp and a wallet that hates you. What is your budget, and how far do you want to go?
Old Sep 8, 2006 | 11:51 AM
Nikon02's Avatar
I want a flatter tq curve with about 400+hp and 400+tq to the wheels. what would a good cam be for that?
Old Sep 8, 2006 | 11:52 AM
Nikon02's Avatar
And i only want to spend around $7k for the motor and tranny.
Old Sep 8, 2006 | 04:26 PM
Black FormulaLs1's Avatar
you could always get a 6.0 block that comes with a four inch bore and go with the new LS7 heads, intake and a cam of your choice..probably great for boost..depends on your comp ratio tho..
Old Sep 8, 2006 | 04:34 PM
8banger's Avatar
If you're only looking for about 400rwhp, do what Cop Car said and get an LQ4/LQ9 truck motor (6.0) and add a 224/224 cam, mill the heads about .030", and an LS6 intake. That right there should get you what you need. If you want to do a stroker, look into Eagle rotating assemblies. VERY strong, much stronger that what most people even need. A 408 would be sweet, but you'd be closer to 500rwhp within your price range.
Old Sep 8, 2006 | 06:15 PM
Nikon02's Avatar
what do you guys think of SLP's ZL 402 setup?
Old Sep 8, 2006 | 06:52 PM
magius231's Avatar
SLP is traditionally quite a bit more expensive then what you could put together other places. Check out Texas Speed, Thunder Racing, Rapid Motorsports, and any of our other sponsors...
Old Sep 8, 2006 | 08:07 PM
Nikon02's Avatar
$3600 for the short block. It is cheaper then the Lunati and i wouldnt have to get a block.
Old Sep 8, 2006 | 08:10 PM
TAQuickness's Avatar
Call HPE ---->
