Honing question
Old Jan 23, 2003 | 07:21 PM
I follow no 1's Avatar
Default Honing question
If I get pistons and my block needs honing can I do it with a hand held hone or will a machine shop have to do it?I know it can be done on a sbc not sure on a ls1.
Old Jan 23, 2003 | 08:41 PM
SStrokerAce's Avatar
Default Re: Honing question
I wouldn't.
First, if you hone without a TQ plate you will make the cylinder round in a manner that it doesn't see when it's running, not a good idea.
Second, the finish on the walls will be to smooth and you will have oiling problems.
Thrid, You need to take out 2-7 thou with the hone, unless you are doing a deglaze either way I still wouldn't.
These blocks are very picky concerning the cylinder walls so I would say no.
Bret
