Cam experts- pick my cam
'04 Vette, MN6,3.42 rear, K&N in Z06 airbox, stock manifolds,x pipe,cutouts.
Right now I have '03 Z06 heads and cam sitting in the garage. The heads will be freshened and ports cleaned up by a local speed shop before going on this winter. The car sees 10K/ year with no track time.
Here's what I'd ideally like to have in a cam:
use the stock LS6 springs
leave the stock exhaust manifolds on for a year
a little lope
good bottom end/ midrange
about the same gas mileage as I get now
Right now our NY emmissions is plug in ODB plug in. I don't know what's coming but I'd like to pass a sniffer if I have to.
I've read the entire sticky about cams twice, but I need some real world experience. Am I asking for too much out of one cam?
Suggestions?
2. Its not worth just getting LS6 heads just "cleaned up" Get at least stg 2 port job done on them. maybe you can trade them in for stage 2 already done.
3. you cant use LS6 springs with this cam. the only cam that you can get without changing out is the z06 cam and thats just not worth it. youll be bored after a month. but you can get away with Comp 918s (non-dual)
4. Get american racing headers
Thanks, Tom
I'm open to other suggestions too.
Thanks, Tom
