What rockers work with ET 11* heads
Old Sep 15, 2006 | 04:57 PM
Rybar's Avatar
Default What rockers work with ET 11* heads
Was wondering what rockers can be run with the ET 11 degree heads.
Old Sep 15, 2006 | 05:24 PM
LSX-Racer's Avatar
Banned - Ed Curtis aka EDC
Stock rockers fit with the provided rocker stands.
Old Sep 15, 2006 | 05:30 PM
Rybar's Avatar
Is it worth it to go with an aftermarket set? And if so do they have to be an adjustable type?
Old Sep 15, 2006 | 05:52 PM
mr2guru's Avatar
Eh.... stockers w/ et stands are about the only ones that fit without machining. I am pretty sure jesel makes a custom setup for the 265 heads though.
Old Sep 15, 2006 | 05:56 PM
skipperbisket's Avatar
Erik at HPE told me that i could run my T&D shaft mounts with the et 245 heads
Old Sep 15, 2006 | 06:05 PM
mr2guru's Avatar
If the stand fits (I know jesel SS stands don't) without machining, you'd still have to shim the rocker stand as the bosses sit higher. Hense the custom stock stand that ET supplies for stock rockers. Otherwise your geometry will be way off.
Old Sep 15, 2006 | 08:35 PM
Bryan@LME's Avatar
LS1TECH Sponsor
LME sells the Crower shaft mount adj. rockers. We had them made specifically for the ET heads. They set up very nice and are less expensive than the Jesel's @ 1175. We have used about 7 sets so far with great results.
Give us a call or email for more info.
Thanks,
Bryan
LME
713-849-4505
Old Sep 15, 2006 | 08:51 PM
mr2guru's Avatar
Thanks,
Bryan
LME
713-849-4505
O'rly? Are the adjustable at the pushrod cup? Aluminum or steel arms?
Very interested, I gave up on my jesels due to fit with the et215s....
Old Sep 15, 2006 | 09:01 PM
Rybar's Avatar
Thanks,
Bryan
LME
713-849-4505
Thanks for the info. How much is a set Bryan?
Old Sep 16, 2006 | 12:38 AM
ls1408cp's Avatar
$1175
Old Sep 16, 2006 | 02:43 PM
Bryan@LME's Avatar
LS1TECH Sponsor
The rockers are 1175 for the set.
The adjuster is at the cup. The rockers are aluminum. They also needle brgs. in the roller tip.
Old Sep 16, 2006 | 03:14 PM
Phil99vette's Avatar
7 Second Club
We've got a set of Comp Cams 3/8" Adjustables we're installing very soon. So far they look like an excellent choice.
Phil
Old Sep 16, 2006 | 08:22 PM
beardWS6's Avatar
I just used stock on mine!
Old Sep 17, 2006 | 10:10 AM
miami993c297's Avatar
Is a set of OEM ROCKERS HARLAND SHARP REBUILD going to fit and work well on a set of FTI ETP 215 with the provided rocker stand?
Christian
Old Sep 17, 2006 | 11:06 AM
Steve Burger's Avatar
LS1TECH Sponsor
HS rebuilds work fine. That is what I am using.
Old Sep 18, 2006 | 05:35 PM
Thank you for your answer Steve,
I guess your heads are the ETP 225, do you know if it works the same for the ETP 215 ?
Christian
Old Sep 18, 2006 | 06:17 PM
LSX-Racer's Avatar
Christian
Yes, you are fine.
Old Sep 18, 2006 | 06:59 PM
Yes, you are fine.
Thanks LSX-Racer,
Will do it when my FTI ETP 215 will go in.....soon
Christian
