Injector size??
Old Sep 19, 2006 | 06:09 PM
fastbasser's Avatar
Default Injector size??
What size injector is needed for a 750+ HP supercharged 427?
As always, thanks in advance.
Old Sep 19, 2006 | 06:11 PM
TAQuickness's Avatar
I don't know the answer to your question, but you might get a faster response from the fueling section.
Old Sep 19, 2006 | 07:22 PM
GuitsBoy's Avatar
Youre probably talking motron 60 Lb injectors, a bad *** fuel pump, new lines, rails, and a regulator. Boosted apps have a smaller pressure differential between the rail pressure and manifold pressure, s you need much more injector than a n/a application.
