sensor question
Old Sep 21, 2006 | 10:03 PM
cjg454ss's Avatar
Default sensor question
what is the sensor on the back side of the driver side head. it has screw into the head. i seem to have broken it off so all i can see is two metal wires coming out.
Old Sep 21, 2006 | 10:12 PM
Ferocity02's Avatar
The only thing back there are grounding straps.
Old Sep 21, 2006 | 10:16 PM
cjg454ss's Avatar
no there is a sensor that threads in, 3/4 wrench or bigger takes is out. i think it has some black plastic clip that got broke off when i removed the heads leaving the two hard wires and the metal piece.
Old Sep 21, 2006 | 10:44 PM
Ferocity02's Avatar
The only sensor on either head is the coolant temp sender, and thats on the front of the driver's side head. It threads into the head.
Old Sep 21, 2006 | 11:52 PM
Jed Z06's Avatar
Old Sep 22, 2006 | 09:10 AM
Chin180sx's Avatar
Oil pressure sesor is on the back of the block the threads are M16x1.5 but im not sure what socket you need to take it off i think it might be like a 20 or 22mm?
Old Sep 23, 2006 | 07:58 AM
cjg454ss's Avatar
yep temp sensor. thanks guys
