Rocker Arms and Camshaft
Old Sep 21, 2006 | 10:13 PM
2002 SS #476's Avatar
Default Rocker Arms and Camshaft
The cam I was thinking about getting was 228/232 .588/.592 (been reading that thats a good cam for stock heads) with 1.7 stock rockers. I wanted to get some comp cams 1.75 roller rockers to use. So instead I would get a cam with 228/232 .587/.589 (.335/.337) using the 1.75 rockers. I know the valve doesn't know how it's opened, but is there any disavantages by gaining more lift by using the rocker arms, instead of the camshaft?
Thanks
Old Sep 22, 2006 | 11:34 PM
ShevrolayZ28's Avatar
As long as the stock rockers are in good shape I would re-use them, they are fairly light-weight and work pretty well. Those aftermarket rockers are big bucks. If I wanted more lift, I'd just get a bigger cam.
